bpb424
http://www.swampsdiesel.com/xtcomme...ance-Compound-Crossbow-Performance-twins.html
What are the specs on these chargers?
I've never heard of them.
they look pretty sweet
These are modified stock turbos..
The low pressure compressor is 71mm inducer, while the high pressure turbo receives a 59mm compressor, with a slightly larger 64mm turbine wheel to lower drive pressure, and increase performance of moderately fueled 6.4L street trucks.
If you have a lot of fuel...then I would suggest an external waste gate as well...
take care~
Dave
how hard would it be to swap the cast wheels for some batmos ??
