Coolant Degas Bottle
madman1234509
mayfield, ny
Here's mine, it's custom. But just another idea. The vacuum reservoir is built into the tank and is on the bottom. No issues. Temps are the same as prior.
SEABEE08FX4
Montgomery TX
Well I ended up going with this, I needed something smaller. And since I'm moving both batteries to the passenger side to make room for the oil cooler, oil filter and coolant filter this works perfectly. Has the right size hose barbs, and takes the factory cap. Made by Moroso for the 05-10 Mustang GT, for 140 bucks it was a no brainer.
SEABEE08FX4
Montgomery TX
That looks nice... How are you planning on bolt it up...
Just going to make my own bracket, put it in the same location. Ditch the battery box, and run a vacuum canister off a Econoline Van. Use the area where the battery box / vacuum reservoir was for my oil filter, oil cooler and coolant filter.
Erikclaw
Central CA
I've been running the dirty diesel custom bottle for a couple years now. No issues. Running Evans coolant in my system also.
I've been wanting to run Evans in my truck, just damn $$ for so much lol. Run it in my KTM 525 EXC and Yamaha Raptor.
Probably pulling the trigger on Mike's, as soon as I get my truck back. Don't feel like relocating another battery so his should work just fine.
CAT35niner
NJ
Yea it's definitely not cheap. I got it when it was $35 a gallon and now it's $45. Amazon is the cheapest I've found. It's good stuff tho. Haven't had any issues
