Buellstunter
So I recently flushed the cooling system to try to revive my oil cooler. While I was at it I replaced the fan clutch due to a fan speed sensor code I was getting. And I also replaced the thermostat. Long story short it def. helped my deltas. Only a 10-13 deg diff going down the highway at 70mph. Was about a 40deg. Diff. Before. But ever since I did all the work the EOT has run between 192-198. 2 days ago I put in a coolant filter system and my deltas went from a 10-13 deg. To about a 25-31deg spread.
So Today I removed the 3/8 return hose going from the intake manifold back to the degas bottle. And the hose barely has any coolant returning to the bottle while the truck is running. Almost just a trickle. So I decided to
Pull the water pump. All seems well with the pump. Impeller is tight on the shaft and bearings are good in it. It actually looked like it was relatively new. (I've only owned this truck about 3 months) the other thing I noticed is the coolant I drained from the radiator is kinda like a piss yellow, while when I pulled the water pump, the coolant in the block looks like brand new green color.. Does anyone have any ideas what might cause the weak circulation, or can give me some direction or Something else I can look at? It also doesn't puke and the most pressure I build in the cooling system even after driving it hard is about 10-12 psi. Normally runs between 5-9psi. And pressure slowly drops off while the truck cools at idle????? I'm at a loss here. Need some help. :shrug:
