Coolant leak need help
Strokethis213
The truck: 06 ccsb 6.0 arp studs bpd air to oil cooler bpd ficm powermax turbo egr ******.
Problem: leaking coolant bad 10" puddle
The truck is in phx az a buddy was using the truck pulling 4 dirtbikes on a 16ft trailer and blew the egr coolant hose so put a new hose on it new clamps boom all fixed next week the truck starts leaking again so I look under the truck and it's wet and leaking on the axle. I then pressurized the system and finally after 5 min I see coolant leaking from the middle of the motor down onto the crank and dripping I used a mirror and I couldn't exactly see the leak but the water pump looks wet. The leak has gotten worse over 3 days from leaking a 3" puddle to 10" puddle. Can the weep whole leak that much and or the o ring for the water pump itself leak?
Any help is gratefully appreciated.
Mesa, AZ
I have seen water pumps piss out as fast as you are putting the coolant in. On that note, check the donut o ring on the intake as well, and the heater tube o ring.
