Coolant temp sensor wire problem!
Littlenoz
I had to put a new water pump in today and when I went to disconnect the coolant temp sensor wire the inside of the wire connector crumbled apart! Can I cut the end off and wrap the wire around the sensor?
Littlenoz
Does any one know of a after market gauge and sensor that will screw right into the stock sensor spot?
Littlenoz
Thanks Tom your the man! I was looking for the pigtail with no luck. I just bought one from eBay via your link.
