Coolant
rlpzzz
Houston
I have searched this topic thoroughly but can't make a decision, what should I run in my truck, ELC or Motorcraft Gold? I have purchased a coolant filter and Restore & Restore + but am lost on the coolant. I plan to change the coolant every three years or 50k, whats the general recommendation?
Dzchey21
wyoming
I run ELC in my truck i just flushed it really well and then put it in. I would recomend changing it at 50k at the most, im going to keep changing mine at 25k but it could be overkill
zabeard
Im just running cheap stuff right now. Prestone all makes. lol
I want to run the ELc by Rotella or CAT, just havent bought it or even wanted to flush the system. lol
The bittering agent? Its to reduce cavitation right?
rlpzzz
Houston
What flush intervals do ya'll suggest when running the Ford Gold with a coolant filter? Is the Restore & Restore+ needed each flush?
Is it necessary to change the ELC as often or more of a preventive maintenance thing?
JUNIOR
Conneautville, PA
These are the directions I have.
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one. You can skip the block drains if you want except for the final drain before adding fresh coolant. You will just have to flush a few more times to get the block clear.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with tap water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with tap water. Drive truck or run on high idle for 60-90 minutes. Drain and flush 3 or 4 times.
Add 2qts VC-9 or 1/2gal of Restore Plus, top with tap water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water if you are draining the block or 5 times if not. This is to replace any tap water in the cooling system with distilled water and very important.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
