WD-40 electric contact cleaner will displace any moisture in the plug and keep it from freezing.
Thanks I'll have to get some of that a day of rain followed by two days under 20 is turning stuff into a pita. Lol
Think that would work on locks as well?
02 ccsb, lariat, 7.3 auto, 4x4, 4" duals, 6637,zoodad
keep it out of the snow...... Never had that problem.
I use Dielectric grease in my snowplow connectors and my engine block heater..
When its not plugged in its about 1ft. Off the ground holes downkeep it out of the snow...... Never had that problem.
It was dry when plugged in it rained that night sad part is there was no ice on the out side of it. Only other time I had problems was my last trk had about half inch of ice on the cord that winter sucked.Before I plug mine in if I notice it's wet I dry it on my shirt as best I can. Another way would be to keep it under the hood where it might stay a little warmer. When if kept mine under the hood it was warm no matter the outside temp. Now I dry it as best I can and tuck it behind the grille. Hasn't frozen yet.
Some idiot zip tied it to the tow hook. :doh::whs:
Dielectric Grease....and tucking the cord up into the grill, LOL
I use dielectric grease and zip tie it to a tow hook with a little slack. When it's not in use I tuck it in behind the bumper and it stays pretty clean.
I've had it happen a few times. Female end of plug gets snow thrown on it driving around all day. Once engine is shut off it gets cold and freezes again.
When its not plugged in its about 1ft. Off the ground holes down.
You must keep your cord wrapped on the front of you pickup. I leave mine at home.
Like you stated WD-40 will help for sure.
That is funny? I wonder what is doing it. Like was stated though WD-40 should help. Maybe my problem is if its warm enough to melt it never gets plugged in. Only when I know it is going to be below zero will i plug it in.
That problem you have would be annoying.
There is benefits to climbing in a pickup that has a oil temp of 60 plus degrees!!
I've also used refrigerator magnets to cover the key hole overnight if I know there is a chance of freezing rain or snow.
OK I was wondering. I know guys that do thou I thought maybe you do. Humidity would play a part there. We are to cold most time to have humidity.LOL IF that is possible.
