chromehound
I searched but couldn't find an answer so here is my question: my livewire asks if I've changed tire size and if I want to correct for them (I do and I did); is this correction for the speedo, transmissions shifting, both, neither?
I ask because someone on another forum was asking about tuners and when I put up that mine corrected for tire size and seemed pretty accurate I assumed it was correcting the speedo and am getting some grief about it and I'd like to have my facts straight. BTW mine came with the truck and no instructions-I'd have checked them if I had them.
Second question: I found in a search that the SCT wil make the truck have a high idle if the DPF is deleted and no sensors are hooked up. My DPF is off but there are 4 probes that are hooked up in my exhaust. My truck will switch to a high idle of ~1100-1200rpm when it's cold out but everything I've read says that if the probes are hooked up it won't high idle. So this has me curious as to if my SCT is making it high idle or if it's had something else done....not an issue just curious.
