bft blue oval boys
It's not tuned related, I refuse to believe that! You just have some crappy lemon pistons in that thing
Gearhead
which tuning platform? SCT tables don't directly mimic H&S tables
just curious
H&S MCC
HD Coated for sure, considering more to prevent further issues
mine was build 9/09 didn't know if they had a bad batch go through then, or if anyone else had knows of a truck with similar build date with similar issues.
i really dont like guys saying if the cylinders have "good" cross hatch just throw pistons in it. That is terrible advice, maybe it has excessive blowby because the cylinders are oval which they always are.... if you are going to do pistons id suggest spending the extra money and having the block measured. In reality it probably needs bored and torque plate honed to be assembled properly. just my opinion.....
I will definitely check into that, now I'm also concerned about my injectors and HPFP screwing up, and blowing all the effort up in smoke.
Agreed, my engine had .010 taper and was out of round with only 100k.
I can't remember. Did you have a cracked piston?
