Crank Case Leakage
militant83
Circleville, Ohio
Ive read all of the threads I could find on CCV Venting to the atmosphere. And a couple times it was mentioned that by doing that it may cause the crank case to leak over time.
I recently installed a No Limit CAI and of course it requires you to reroute the CCV.
Has anyone experienced any leaks after rerouting your CCV?
04cr450
harford county, maryland
nope, not one leak. just make sure you run a big enough hose for the ccv... 1"id... i ran this size all the way behind the fuel tank, good to go.
