Kyle308
Hey guys got a buddies 09 6.4 the injection pump locked up on it. I pulled the cab put a reman pump from ford in with a new cover kit. Cleaned out a the rails and lines. Bled the fuel system all morning. Went through 6 gallons of fuel bleeding from the rear banjo and shrader valve. Still no start. Rail pressure is at about 6k when you first hit it then drops to 5100 still no start. Rpms reading sync is okay. Interlock is good. No codes. It kinda pops no smoke no hydra lock. New batteries new starter too. New fuel filters. Anyone have any pointers? I'm thinking about doing a compression test on the cylinders I can easily get to. Thanks!
