Cruise Control dead?
Corb@CorbinShipping
Autryville, NC
Thats what im working on tomorrow night after work. Process of elimination. Any suggestions on checking or replacing the pressure switch?
Sent from my SPH-L900 using Tapatalk 2
Anybody have the pressure switch part # handy?
Mine was the brake pressure switch. I threw a code. P0703, I think. Let me see if I can get a part Number from the one I bought. It is a pain in the ass to replace, as it is on the bottom of the master cylinder.
Part # 3L3Z9F924AB. It was 52 bucks from Ford. and they had it is stock, as I understand that it is a common problem...
Bigdiezel
How long of an Install time on the pressure switch? Mine throws that code every once in awhile and the cruise wont work.
Corb@CorbinShipping
Autryville, NC
If your wrists are double jointed, I would imagine that it would only take 5 minutes... I had to move the coolant overflow jug... Took me about 30... But I wasnt really in a rush either...
WILD_PHIL
East TX
So I unplugged the switch under the hood with no luck. Ford charged 45 bucks for a new switch. Figured id take the one out of my 08 and put it in the 09 to see if it works before I throw 45 bucks at the truck. Gonna do that on my lunch brake today. Am I going to loose my brake fluid when I do this?
Sent from the cabin of my Boeing 6.4
Beans71086
North East, MD / Clearville, PA
Aweful long lunch break Phil... :poke:
How did this turn out for ya?
WILD_PHIL
East TX
Didn't have time to swap out the pressure switch. But if I pump the brakes turn the truck off and on ut works.
WILD_PHIL
East TX
45 bucks at ford. The parts guy knew exactly why we were buying it. LOL
WILD_PHIL
East TX
I hung on to mine just to be on the safe side. Im going to keep using the faulty one in the truck till it completely gives up. Was it 45 bean?
white6.4
My cruise control wont work also and the code I receive is po602. Anyone have this problem I looked up the code and all it says is power train module fault.
