CTC's first 6oh....
DEEZUZ
NO PUKESTERS
NWI
Oil was changed religiosity. .. if 6oh is local, i think he knows the owner. This is why this failure was such a shock
DEEZUZ
NO PUKESTERS
NWI
It also wasn't the use of aftermarket oil filters. Looks like this thing had the original cap on it. You can tell years of removing it with channel locks. LOL
DEEZUZ
NO PUKESTERS
NWI
I have a feeling I've worked on your truck years ago... but I can't recall
drunk on diesel
That's a bummer about the lifter :(
All the lemmings talk about how horrible the 6.0's are about head gaskets, EGR coolers, etc.
Lifters are the true Achilles heel of the 6.0
Thankfully is rare enough to not loose much sleep over.
DEEZUZ
NO PUKESTERS
NWI
Dude this is not a rare failure... I have had them fail as low as 55k.
I've probably done 11 motors this year due to lifter failure
webb06
Seneca, MO
We've yet to see one. Which is odd because we work on probably 5-10 trucks a week typically.
drunk on diesel
Head gasket, injectors, EGR, FICM, high pressure pump, oil cooler, etc. All FAR more common than lifter failure in my experience, and none nearly as damaging or expensive
DEEZUZ
NO PUKESTERS
NWI
I picked up a cam local last night. Looks like one lobe got kicked on its way out of the block, but nothing too serious. I'm going to send it in along with my heads today to get polished and specd out. Probably going to have them do valve seals also and inspect guides
DEEZUZ
NO PUKESTERS
NWI
Also got my IPR updated stainless HPOP reservoir screen in
DEEZUZ
NO PUKESTERS
NWI
DEEZUZ
NO PUKESTERS
NWI
Debating breaking down the heads myself. The shop wants way too much to do the work.
How often do guides go bad?
co04cobra
WV
Not that often but are you still having them deck the heads and magnaflux ?
DEEZUZ
NO PUKESTERS
NWI
Yes. I may break down the valves myself though. 600 each head for guides is a little high IMO.
DEEZUZ
NO PUKESTERS
NWI
I broke down 2 valves. Both on the rocker with the failed lifter. Looked amazing, no scoring what so ever, came right out, went right back in, no issues. So their getting decked n checked right now. Cams going in to get polished
DEEZUZ
NO PUKESTERS
NWI
2 lifters failed. Neither spit bearings out. But the rollers are intact, just very chewed up
