Custom degas bottle
gumper38
I'm thinking around 275-300 that is with a sight gauge, bung for coolant filter so you don't have to "t" into other lines and anything else you might want. I can also powdercoat it if you would like.
Sent from my SPH-L710 using Tapatalk
Mwilbur516
I'm thinking around 275-300 that is with a sight gauge, bung for coolant filter so you don't have to "t" into other lines and anything else you might want. I can also powdercoat it if you would like. Sent from my SPH-L710 using Tapatalk
That sounds like a great price. I'm very interested , not just for my truck, but customers too.
Sent while driving, drinking coffee and threatening to kill people in traffic.
strokin6L
Springville NY
I built this tank for my truck a couple years ago when I needed somewhere to route my coolant from the oil cooler because of the ported intake. I think I still have the cardboard templets if someone might be interested. The two threaded pieces on the one side act as sight gauge.
Do you have any pics with this installed?
gumper38
strokin6L
Springville NY
Looks like you have the coolant from the oil cooler(5/8" line) going to the degas...right? How is this sized in comparison to the stock tank.... smaller? I would be very interested in this with the same size ports you used in the exact same locations.
gumper38
Thats correct 3/4 to 5/8 hose coming directly from the oil cooler just because a 5/8 fitting is all I had at the time and never went back and made it 3/4 all the way. The capacities are pretty close maybe a couple ounces different. That is running my tank just shy of half full and to the min on the stocker.
true98jeep
Troutman, NC
Can you build this to incorporate the 3/4 line? So that those running absolute's delta line kit could run directly to the port with the exact same size in and out like Strokin6L was saying? Count me in on one I would love to get one of these. I will even pre-pay to secure one of the first batch.
gumper38
There is a 3/8npt threaded bung on the tank and you can put whatever size barbed hose fitting you would like.
strokin6L
Springville NY
Oh OK...cool! Instead of having the front of it coming to a sharp point....would you be able to square it off and have the bungs for the sight tube on the face of that?
gumper38
Yes I like that idea it would not be hard to adjust.
