yotaneck13
- Joined
- Jul 10, 2012
- Messages
- 510
- Reaction score
- 0
Ok i had this problem a while ago. I was on my way to meet a fellow psa member. He was meeting me to trade his injectors and turbo for my dirtbike.
Anyways cruising down the interstate truck starts surging. Like something was binding up. My buddy and i thought the rear diff was locking up. So i limped it back home. I pulled my rear axels and driveshaft. This seemed to fix the problem.
Drove on my front axel about a week and it started doing the same thing again. This time it was doing it under light pedal on back roads. I yanked my transfercase and rebuilt it. New chain and berings and seals. I reinstalled the rear axels and drive shaft. Problem went away again.
Fast foward two weeks to last saturday. Problem is back. Again just driving normal back roads. Im holding my foot steady and it sounds/feels like im feathering the throttle. I hooked the modis up. Multiple codes from way back.
I did get a map sensor code and a glow plug indicator code. Wts light does not come on and hasnt for a while. (No blown fuse that im aware of. Ive checked them several times. Both under hood and above e brake.)
Injectors all passed the buzz test. Glowplugs passed their test. Cylinder 8 failed contribution test. Im stumped. Could a bad map sensor cause this? I replaced gauge cluster and throttle sensot on pedal last fall when i lost my pedal completly.
Under wot it does not surge and my boot gauge settles at just above 20 through out all gears. Truck is currently not running anykind of tuner. I just have an intake and straight pipe exhaust. Any help would be appreciated...and or bashing if ive missed something simple.
NOTE: truck is a 2000 f350 cclb drw. 4x4 auto. Just over 215k
sent while hittin' easy street on mud tires
