Cylinder #2 misfire and exhaust valve not closing all the way
dozer
Superior Twp
Quoted from my mechanic.
"It's an 08 6.4(egr/dpf deleted), 53k miles, just did new head gaskets/studs/elite push rods/springs. did the fuel system priming and cranking for a bit to start it, got it started and about 30 seconds into idling, it started misfiring cyl. #2, swapped cyl. 2 & cyl. 4 injectors, misfire stayed with cyl.2. Checked compression and its 0 psi, not even a bump in the needle. bumped it over to check valve operation, and I&E go up and down perfect. BUT the exhaust rocker never loosens up (not able to wiggle it) like the rest of the rockers. loosened up the rocker stand when both rocker were on overlap and applied air to cylinder thru glow plug hole and it holds air and it actually pushed the piston down a little. SO can these rockers stayed TOO pumped up to not allow the valves to fully close?
AND the engine never revved over 1500 rpm since first started with misfire.
Thanks, this things got me worked up a bit"
dozer
Superior Twp
He checked the length against the intake pushrod and its the exact same length. It's ran fine since last year when the pushrods were installed.
zippyrat
witchestitty, kansohama
you can put the pushrods in upside down I heard of a guy doing this, and he had simalar problems .
I think there is a gold end and a silver end. iirc
Bair
Pinehurst Idaho
On my truck when I got it cylinder 7 had 0 compression. One pushrod was not installed correctly which held the valve partially open.
Bair
Pinehurst Idaho
Nope, pulled th pushrod to check for straightness, reinstalled it, an compression was right there within spec.
Big Angry Hillbilly
And the pushrods have different colored ends because one has a metal surface pivoting on it all the time (Rocker arm end). The color has nothing to do with direction, only an indicator of what end was where in the engine.
