you are right , i think its a skewed number that gets worse the high the boost gets, i just verified that over 50 psi it was no longer accurate.
Mike haller actually discovered it on Mals truck when he put mechanical guages on it for a couple reasons, for one, there was no way to read low pressure turbo boost, so he put a guage in for that, also his factory egt sensor was messed up, and the only guage pods you could get were 3 pods, so they did two boost gauges. Every time mike would data log with IDS on the dyno his numbers were always higher on the gauge than the ford computer would pick up.
So i decided that i was going to make my harness for the dash daq so a guy could data log a run without IDS if if wanted to, when i was setting it up i realized that the factory map wasnt reading right with what i had for guage pressure to verify that my calibrations for the dash daq were correct.
There must me some table in the ecm that isnt quiet right, and it doesnt really suprise me considering that the factory turbos only make like 36psi on a stock setting.
