Since the OP isn't planning on building a trailer queen sled puller, I feel like someone should mention that a clutch that will hold ACTUAL power in the ranges being thrown around describing these clutch ratings will drive like fresh dog sh*t smells on a hot summer day.
9.8 times out of 10 a guy driving a dual disc on the street that says it has great shifting and driving manners makes NO POWER. How many responses in this thread were STOCK injectors? LOL How many of the others have pulled even 500 to the ground on a legit dyno?
I can put together a single disc that will hold 500 wheel ALL DAY LONG, and shift better and quicker than a stock clutch for ~350 bucks! Will it hold ACTUAL power? NO. Above 500 to 550 and all bets are off. Time for a torque converter or dual disc that simply WEIGHS too much to shift well, but can be made to hold.
This leads to the other 0.1 times out of ten a guy running a dual disc clutch on the street that says it shifts good.... is lying, or just too ignorant to know how horrendously sh*tty his truck actually drives.
The last 0.1 times out of 10 the truck actually makes power, the clutch holds it, and the truck shifts fast and the owner rebuilds the trans often enough to keep syncros in it on every other oil change...
If you want to make the kind of power being thrown around in this thread on some of those clutch ratings and actually do it with a manual, you better get ready to shift niiiiiiiiiiiiiice and slow.... or tear your trans down pretty often when it's grinding, hanging and popping out of gear.
Fwiw, a buddy of mine with one of those "600hp" Southbend clutches pulled clean through one repeatedly at ~500hp and after they kept asking if it was a cummins and him saying no, it was a 7.3, they continued to tell him that he was not pulling through the clutch with a 7.3. So he installed another one, and proceeded to blow clean through it too.
Just so you know, those boys apparently don't ever expect you to actually make the power they rate those things to with a 7.3. I guess they hope you'll tool around on STOCK injectors at 241rwhp like a couple in this thread, lol. Boy.... that's real demanding, lol.
God dry clutches and pos plastic master/slave assemblies are the best. A nice wet, multidisc clutch with 3 frictions constantly submerged in fluid being circulated to a front-mounted cooler would be horrible.
:drool:
On Edit: And if you plan to slide the clutch AT ALL.... stay far away from ceramic. It has incredible friction to weight, but you cannot glaze it like that.
