nighthawk285
You want for the front or the rear?
Ford 10.25"/10.5 specs
Carrier cap bolts - 80 ft/lbs
Ring gear bolts - 95 ft/lbs
Backlash - 0.006"-0.010"
If you mess with the pinion or crush sleeve
Used pinion bearing preload - 6-8 in/lbs
New pinion bearing preload - 20-35 in/lbs
