08strokin
What's the price on this kit?
$1399 for me back in the day
I'm not an expert, and I'm sure it's not an "issue" as many people do it, including your custom set-up and Jake's kit. It just seems that draining oil from a hot turbo over the cam *might* be less good than draining that oil in the factory location. But like I said, I'm not an expert, and many people have had success with other set-ups. I'm very happy with the set-up on mine, and it didn't seem difficult to run (albeit I just watched Wes do the work I wasn't leaned over the engine).
What was the reason on your set-up that specifically did NOT want the drain at the back of the turbo?
~Mitch
Many of us drain the turbo the fuel pump hole in the valley just to have less issues. The routing of the hose is just flat better, doesn't rub anywhere, gives you room to work and install easier, etc.... I've been doing them that way since 2007... maybe early 2008 and I know others were doing it that way before I was. To the best of my knowledge no one has had an issue with the small amount of hot oil dumping onto the unused fuel pump lobe of the camshaft.
