DI cam
79broncoidi
Guilford, CT
Well i have decided that im never going to need the cam i have. It is from DI perfomance. I dont know the exact specs of it but i do know that if u call Di they will tell u what u need you know. I do know that valve reliefs will need to be cut in pistons. The cam gear has been welded on by DI. It has been installed in motor but never started. So it is new. Im asking 500$. Thanks for looking.
79broncoidi
Guilford, CT
Well the rest off the motor was parted out over a year ago one my boss kept some. Just no bights on the cam last time so i thought i would try it again. Thanks for looking.
79broncoidi
Guilford, CT
Hmm i always thought they only made one cam. Eather way to be safe i will say valve clearance needed and you can check from there. Bump it up top i want to sell this. Truck needs other things.
