DIY gen 3 hpop parts
Short Bus
kansas
I have the IH power steering reservoir and pump gear that can be used to make a gen 3 style hpop system. The gear will need to be slightly modified, iirc the gen 3 pump shaft is slightly larger than the IH pump shaft. Asking 300 shipped to lower 48. I'm going to look but I will have up to 3 sets of these.
Magnum PD
VA
Haldex 4f665 pump. But you gotta change the housing for the reverse rotation.
Short Bus
kansas
last time i checked ( been a few years) unlimited diesel sold the check valve and line kit. then all you need is a pump.
