DIY injector build
ja_cain
Btw, that previous post was a joke. I don't even think that power supply can even meet the current demands of the electrical side of the injectors. Factory idm (with correct input signal) seems like the way to go.
N2GN2
Montana
Looking to order an Arduino/breadboard and MOSFET to generate signals to the IDM. Ultrasonic cleaner will be here Tuesday. Waiting for my 4.5mm security socket. Check out the progress!
N2GN2
Montana
I want the fast oil mod. Add an extra hole and enlarge another.
superpsd
Missouri
Looking good. I have a week/half off and need to wrap up my DIY sticks as well. Wish you good luck.
superpsd
Missouri
BI codes with the split shot ports TIG welded shut with 200% tips. They may or may not work so well. If they do not work I have been collecting new BD code injectors as I come across deals. I have a Honey Badger SR on the shelf to help feed them.
superpsd
Missouri
The largest standard A code is 275cc where as the IP is machined to the maximum as so I have read around the forums. No one stated the dimensions for the IP. You may be able to dig around. There was a reply on PSN that said a 275cc A code would be a 385cc hybrid.
