Thanks a lot for your reply. Nice to hear from someone that has a direct comparison, without other changes.
I don't really think it is the coils, because the compression feels about right. It is just the rebound that feels too light or soft. The truck seems to rebound too fast and bounce a little after hitting a bump.
On an adjustable shock, if you're getting, for lack of no other term, kickback from bumps in the road in the rear end, do you want to firm up the shock it soften it. Currently on my drive to work there's a section of highway where the joints in the concrete are spaced at just the right distance apart that it's giving the rear end of the truck a nasty kickback. 3 hits in a row until it settles down for a second before doing it again. Dam ccsb truck, my fathers cclb was the perfect wheelbase and met the expansion joints perfect on both axles at once. I'm not talking about a $200 each shock setup. Thinking more like some cheap azz rancho 9000 adjustables for now. Hoping some traction bars will help out like everyone says they do in a couple months. Just not sure which way to adjust for that kickback.
Swap the springs for carli and it will resolve this feeling.
I only say this because I had the exact same experience with the icons and fox shocks.
Are you running 5100s or 5160s?Glad I went with bilstiens when I blew my icons
I have icon coils with bilstiens and it works perfect.
Which Icons were you running and how did they compare to the Bilsteins?
Were the icons not rebuildable?
Pmf makes a limiting strap kit for avoidance of that scenario.
