7.3powerstroke00
Nice! I like Marty's set up!
Heres mine
XDP sump
Using all -10 Jegs push Loc fittings black anodized AN fittings and 5/8 Parker 801 Push loc hose (sump to pump).
Then into a Dahl 150 over the frame
Into a Fuelab 41401 In the stock location on a custom made bracket
Using all -6 Jegs push loc black anodized AN fittings with 3/8 Parker 801 Push loc hose from the pump to the y-block.
For wiring, Jegs fuel pump relay wiring kit w/ 10 gauge wiring, build in relay and circuit and additionally tapped into the ford relay so the pump shuts off like stock.
There isn't one out there for the fords yet
It deffinatly looks more compact, but Martys setup speaks to me for some reason. The size of the hoses going threw it and the big cat filter(which I can get at work) plus the gauge right there for you to monitor it. I like the elongated look of it. It adds visual appeal if you ask me, not everything clumped together like everything else on these trucks. Plus it looks to be easier to work on if, IF you ever had to. Pretty snazzy setup if you ask me. I want one. I'll have to give him a call.
