at minimum, 500miles of cheap nasty diesel rated oil.. so rotella 15-40 should be used.I used cheap oil for the startup and hot retorque. Then put in Mystic 15W40 oil. Blend of synthetic.
It's not bad. I started it up, cold. plugged the vent hose and turn oil cap over and not much air when I did then.
Throw some cheap Rotella in there and run it for a 1000 miles or so. You gotts be a little mean to a motor when it's new. Let it know who is the boss.
yes nasty cheap oil for break in.. go do a brake stand and let her eat..WHO'S YOUR DADDY?!?!?
I can do the rotella if that's what yall think can help.
always break in a motor with conventional/dino oil.. synthetics are designed for less friction. like andy said, you have to seat them rings. so the crappy oil works best for break in..Synthetic? Blend? Conventional? Not sure what is preferred.
Cue jimdawg
correct. no harm.. just hasn't set in place yet.. put rotella in it. do a smokey burnout and drive the ballz off it.. if you ever watched how guys or shops with engine dynos break in a motor then you will understand..Have I done any harm to the engine or just not done the job right YET? Put Dino oil in, run it, work it and hopefully that will set the rings.
why cant people here comprehend what we tell them?I meant cheap dino diesel oil.
and its bottom of the barrel oil.. mobil delvac is just above it.. take your pick.. even walmart 15-40 will work..It's about $80 for 16 quarts.
Delo
