doors dont shut tight
johndeerezach
wellman,IA
hello i have a e99 250 sd and i bought it like this. the doors dont seem to shut tight either side its and ext. cab, so i am wondering if it is the latches on the suicide doors? has anybody had this. thank you in advanced.
DIE5EL
Northern Indiana
My wife has a ecsb and doors are the same way. I lubed the rear latches with a good penetrating oil. Fixed the rear for the time being. Maybe adjust the striker a little. The front doors just need new door seals. They are wore out and won't seal tight. Sorry not much help for ya
Sent from my ifone
Arisley
Arlington, Texas
You can pull the door seals off and thread some silicone tubing through them. Cheap, not that hard to do and it seals so tight that it will actually be hard to close the doors with the windows up until it breaks down a bit.
DIE5EL
Northern Indiana
I used a product called Kroil. Good stuff. Been about a year since and it's still working pretty good.
Sent from my ifone
DIE5EL
Northern Indiana
I also used it in the lever in the extended cab doors that kick the dome light on and off. I had a problem with the lights turning on going down the road. We sell it at the dealership I work at. Not saying it will cure all your rear door problems, just saying it worked great for mine.
Sent from my ifone
Viking
Minnesota
That's awesome! Get that at any hardware store even.
Thanks!
03international
Centreville
mines a crew cab, going down the road some of the doors creek. if you pull them real hard it stops until you let go and they creek again.
patrickke
Lexington,ky
Andy do you know how much it took to do your front doors?
johndeerezach
wellman,IA
that is also something that sounds like a great idea. what size did you use?
Denver
America
My 02 supercab does the same thing and I'm gonna give the tubing a try. Do I use 3/8" dia tubing? And are the the strikers on the superdutys adjustable?
indyF-350psd
sw - indy
yes and yes....i just used the 3/8" clear tubing from lowes....its a little stiff at first but it breaks in nicely during the summer....definitely dont wait and do this during the winter....the strikers are adjustable....
