Dorman Bellowed Up Pipes... (Problem)
DZL JIM
North East Ohio
Where are yall buying these? I think im gonna give em a try on the obs when I swap my motor
You have to get them online.
Local parts stores don't have access to that Dorman part number.
FWIW we use Ford replacements. $140 for both up-pipes and 2 new donuts. If they lasted 15 years and 300,000 mile the first time, I expect they will do it again.
.....it just me and a Dorman thing. Been burned once too many times by them.
Agreed, I keep away from their stuff as much as possible. It's impossible to run a repair shop and stand behind crappy parts.
littleredstroker
where the antelope play
Not an issue with dormans, dont mean to hijack here but is there an easier way to mount these? I got a set of DI uppies and out them in last week. the passenger side is solid to the collector, the drivers side is seperate. I had hell getting them in. I ended up installing with all the bolts loose except the collector clamp that was tight, i then marked the drivers side connection with a sharpie, pulled the turbo and uppies BACK out, tightened the connection on the drivers side down, and then re installed everything.
There has got to be a different way to do this. anyone have any input?
