Is the turbo is use THAT much bigger than stock?? Otherwise anything more than 4" is a tad bit of overkill. If you do pull off a 5" down pipe I'm sure you could get more than one order to fill.
Trimming/bending of the firewall seam would be required on top of the 5" dp fabrication.
