fordracing2105
- Joined
- Oct 1, 2015
- Messages
- 13
- Reaction score
- 0
Well I searched and searched and tested I'm running out of info. So I found this site and joined to ask u guys some questions.
Truck is a 97 7.3 that is not firing at all on the driver side. I drove it about 100 miles one day left it sit till the next weekend and as soon as I started it it was clearly on running on 4 cyl. I have checked and replaced the uvch gasket with one I had. I checked ohms on those injectors all came back at 2.6 to 2.8. Checked continuity from from uvch connector to idm plug. Connectors at uvch don't look burned or bad. I picked up a used idm that was suppose to be from a running wrecked truck but I don't know that for a fact. I took my chip out to see if that was a problem. Pulled some codes it had 4 but I can only remember 2 of them the other got booted out of my computers memory. The are
P0276 cyl 6 injector circuit low dtc
P0206 open circuit #6 injector
That the other two had something todo with high low. I have to pick up the scanner to double check those.
Also the check engine light is only on when truck is running it's not on with just the key.
Any help is greatly appreciated
