dry sump HPOP
Vader's Fury
Chesapeake City, MD
I would dedicate an entire section to feed the HPOP. When at full tilt with a hot set of sticks you are going to need a lot of flow. Just shooting from the hip here at the moment - when I was doing the math I figured I needed about 12GPM for a hot setup just for the HPO system at 3K RPMs at the minimum.
Of course that assumes you are trying to build a full tilt 7.3 and need every ounce of everything thrown at it.
I would say that if you are putting the time and money into a dry sump setup, then your assumption would be correct.
Although I have seen otherwise over the years.:flush:
thatdude
The goal is low 10s out of a CCSB OBS HUEI 7.3, fuel only. I think I'm around $15k invested into the short block?
thatdude
I think it's very doable with good gearing and traction. Nitto drag radials all the way around, 08 axles, ARB lockers, 4 link front and rear.
Still debating on if to dry sump or not but leaning towards yes. Though the truck will be street driven, atleast occasionally. It will not be a dedicated track truck. I've spent WAYYY too much on the interior to be limited to the track.
