dual hpops
Pizza pig
MD
The high volume pumps from bob need to have custom ipr tuning done to get right. Ill wait for kyle to chime in.
faster6.0
I've got a warren dual pump setup coming here in the next month.
windrunner408
Can someone please explain how a dual HPOP setup should be configured for optimal performance?? I think this is what the OP is asking for here. If nothing else can it be explained how the Warren and Elite setups are done??
faster6.0
In a nut shell... An auxiliary 03 style pump is belt driven off a custom bracket on the front of the motor, tieing into the oil rails. I'll post more
Info on before, install and after the Warren setup.
windrunner408
I kind of figured that much. I am more concerned/confused about the ipr valve. Do these setups require two ipr valves.
colinmitchell111
Findlay OH
Very impressive Jesse. Is that just basically running dual stockers? How much will that setup cost? If it is dual stockers, how does it compare in output to the dieselsite adrenaline pump with the hpods?
Jwarren
No the 2nd pump is just a 2gpm 4000psi hydraulic pump. I feed it into the pump cover test port.
Duno for sure close to 1400$ complete
From my smart car.
windrunner408
I think that is where it pulls it from. Dunno if you watched the whole video or not Adam but he does have more pics of it (kind of like in a slide show format) that shows a line coming from the bottom of the oil pan and going to (what I think is) the pump, and another going from the pump to (I think) the test port on the HPOP. Pretty sweet if you aske me. I wonder how this would work with Bob's HPODS.
TooMuch03
West Bend, WI
you're probably right, I usually just skip vids at work because I can't listen to the sound. Everyone would be like wtf is he doing, obviously not working.
