E fuel and the stock fuel line questions
Strictly Diesel
Phoenix
Hmmmm...the OBS Race kit (with Fuelab pump) should have had a length of black 5/16" fuel line and 2 clamps for the return. That might have been a screw-up on our part if you didn't get it, I will need your last name to look up the order and see what was billed.
zilla68
Moore Oklahoma
yep dennis, no 5/16 hose at all, I got one longer piece of 3/8 and another shorter piece of 3/8.
I ordered more 3/8 and 2 fittings and you shipped them out today, order number 44521 should give you what you need, last name is same, might have had a different shipping address though, its been a while since I ordered it.
no big deal dennis
zilla68
Moore Oklahoma
Dennis does stuff NO OTHER VENDOR DOES......................PERIOD
Vendors should take lessons from Dennis on customer service, the guy has it down to a science and "gets" the words customer service.
Dennis you rock buddy, it really wasn't a big deal.
Jomax
Arizona
X2!
zilla68
Moore Oklahoma
now who has a picture of their install of the 5/8 tube in the sending unit. mine is installed but it sure don't fit with the fuel lever arm on
Magnum PD
VA
Dennis emailed me when I was still wet behind the ears on 7.3 aftermarket.
You da man!
blackcloudpsd03
Let me get this straight before I start my e fuel. .. So the line comming off the selector switch (to the motor) that's where you cut the line and put inlet side of the electric pump? Then outlet up to the motor?
gnxtc2
Bergen County, NJ USA
Sort of.....
- From the selector switch outlet to the inlet of the pre-filter.
- From the pre-filter outlet to the inlet of the fuel pump.
- From the pump outlet to the inlet of the post filter.
- From the post filter outlet to the metal feed tube where you originally cut the hose by the selector valve in the first step.
Billy T.
[email protected]
blackcloudpsd03
And just hosse clamps will hold the pressure in place? For security purposes could you use a compression fitting with a hose barb on it?
gnxtc2
When you remove the rubber hose off the metal supply tube, there is a swag on it. You can see the swag on the upper tube (return) at the end of the rubber hose. I slid the hose over the swag and clamped before and aft. The clamp at the end of the hose was used to close the end of the hose. I ran 90 lbs of fuel pressure and it held fine.
Plus, how many fuel injected cars have rubber/hose clamped lines coming out of the sending units with in tank pumps.
For a test, swag a piece of tubing and hose clamp a hose to it. Now try and pull it off. You'll wind up tearing the hose before it lets go.
Billy T.
[email protected]
