flynhawn50
- Joined
- Feb 5, 2018
- Messages
- 1
- Reaction score
- 0
I just installed efuel mark fugazotto and having same problem will run for 10 minutes at idle then die. If i try to drive truck it will die out with no gas coming from schrader valve. Filters are filled top then i have to pull gas up through inlet fitting on fuel block connect everything up it will start up run for a few minutes thensame thing all over again.I installed one of the kits mark fugazzotto makes. Basically pre and post filters with the stock SD pump, the the regulator block.
Anyways was working fine for about 10 miles, then keeps pulling air. I can fill both filters, then it'll run for a bit, then repeat. When I pull the pre-pump filter, it'll be basically empty. All fittings are tight.
Running the factory selector valve. Had no problems previous to the E-fuel.
What I'm sorta wandering is, I don't have the in tank strainers anymore. They broke off so I replaced them with hose with tees at the bottom so it won't suck to the tank. Now could not having the strainers cause it suck up the foamy return fuel, therefore not drawing enough fuel to keep the filters full? Or am I way off?
Tomorrow I'm going to pull the outlet line off and see if it'll just pump into a bucket.
I can give YouTube links to the fuel system if needed.
Sent from my SM-T817V using Tapatalk
