jdeeg4276
So buzz failed on #8. Swapped a injector and no change. Swapped ficm and pcm no change. Changed leaking ball sockets at hp oil rail with Ford new oem. Have low voltage power to injector. No high voltage power. Swapped out injector harness and same issue. Hpop operates good. Any one else seen this before?
