UNBROKEN
- Joined
- May 18, 2011
- Messages
- 2,788
- Reaction score
- 1
I added the EAS pyro and fuel pressure gauges this morning...mostly so I can watch lift pump pressure. All the works just fine.
I have the gauges set to analog and I have the color set to match the factory gauge pointers....it's always worked perfectly.
After updating the CS for the EAS stuff in MyStyle everything still works but the pyro gauge color is stuck on red and doesn't move as it should when temps increase. I swapped the gauges and with ECT in that spot the color works fine....put EGT on the opposite side and it's still stuck on red.
I did a factory reset on the CS and it's still the same.
When I first hooked it up this morning, before I did the MyStyle update, both gauges were working fine and the selected color. Only after the update did the color go weird.
Anyone else have this happen? Is there a fix?
