Efuel...best parts to use?
97Powerstroke Boy
Mercer, PA.
Hey everyone....still working on putting together an Efuel settup for my truck. Want it to be reliable and doing stage 1 injectors, but want room to grow in the future. Want to know a good regulator, pump, lines and fittings to use. Also would a sump be a good idea? Thanks in advance!
Sean
jwlandry
S.W. Louisiana
Aermotive or fuel lab regulator
Superduty factory pump. They are made by Bosch.
For the lines just make sure they are diesel rated and will hold the pressure.
I'd go JIC for the fittings. They require nothing special when using them. Just put em together and tighten them up.
I'm in the process of doing mine right now. I'm doing the plumbing under the truck so that if I ever want to i can run 2 pumps instead of one.
old man dave
Petaluma, CA
It would also be helpful to know just how much you want to grow after the stageIs. Theres a difference in planning on 375hp and 500 or 600hp
Strokersace
Towanda, KS
Call Marty, he'll get you set up with whatever you need. He's got mounting plates cut that are universal to any pump you wanna use. (a1000, Walboro, dual stock) Just add a pump and filter housings.
http://i1103.photobucket.com/albums...8-9E34-E05B62284816-8761-00000ACCC80C46F7.jpg
That has got to be the cleanest off the shelf setup I've seen to date. I built my entire system cause I didn't like how most were setup - big loops of hoses all over the place etc. Mine might be spread out on the frame more than others but its clean and could pass for factory.
GO BIG OR GO HOME
Graham, NC
neverkickn
AR
I wish someone would make a fuel system that mounted to the top of the frame so that the filters are tucked in better. Other than that, that kit looks fantastic.
SDstroker
SE, SD
Heres another option if you wanted to go with SD pumps.
Marty
Elkton, MD
These fuel systems show the most on old body style trucks. They stick down no more than 5 inches below the frame rail, therefore only 2 inches of it is visible from the outside the body. When mounted in front of the rear tire it is still higher than the bottom of the frame rail at the front of the truck. However you can flip the mounting bracket and Mountain on the top of the frame rail, it is a harder install but it will put the filters two inches higher. I did this on a lowered truck, and the filters did not hang down as low as the transmission crossmember.
A1000 is 1450 shipped with aluminum bracket. Soon I'll go back to the stainless steel brackets and the price will return to 1550.
Marty
Elkton, MD
This one is mounted in a standard position. Like stated earlier if the bracket is flipped, they would sit 2" higher.
Marty
Elkton, MD
I use Walbro pumps, they sell for $1150 shipped. Alternatively you can purchase the kit without the pump (if you already have a super duty pump) for $1050.
Also if you have a regulated return already I can attach to that, and reduce the price another $3-400.
neverkickn
AR
That is pretty slick. If I hadn't already fabbed a bracket for my filters, I would be all over that. It looks like it could be mounted inside the frame rail if one where so inclined. Is that the case?
Marty
Elkton, MD
Yes, If you have a 2wd or a ccsb, cclb, exlb.
Kits come with everything. On most kits no factory part of the fuel system is used.
PsRumors
Cartersville, GA
Wanting my filters not to be seen and to be located above the bottom of the frame rail I mounted the post pump filter in the fender well of the bed.
Will be replacing the rubber hose with braided and still trying to find a sD plug to wire in.
DZL JIM
North East Ohio
STD cab mounting sucks..... no where else to go tho..
For OBS (like picured above): Get rid of the front tank and put a F26E 38 gallon tank in the rear. Plenty of room for the fuel stuff where old front tank was and you have almost as much fuel capacity as oem. Plus you get rid of selector valve, can sump it, etc, just a nicer, cleaner set-up.
