The6.7LPowerStroke®diesel engine has two separate cooling systems:
•The engine cooling system,called the primary or high temperature cooling system,
•The power train secondary cooling system, a low temperature system which cools the Charge Air Cooler(CAC), fuel cooler, EGR cooler and transmission oil cooler.
Both systems flow through the radiator.
Sent from my SM-N900W8 using Tapatalk
