elite diesel nozzels DIY
youngstroker
keep the injector knowledge comeing, i have a general idea on how the injectors work but not sure what goes in to building performace injectors.
strokin6L
Springville NY
Garrett, i took a couple injectors apart just to see. It's really not that hard. But be carefull when unscrewing the barrel from the body. There are a bunch of parts at the bottom.
Stroker04
Gettysburg PA
If the shim is between the spool valve and the injector body you can't increase fuel capacity? The only way you can increase the fuel capacity is by machining the plungers? Am I wrong?
windrunner408
Adding a thicker shim between the solenoid assembly will increase the the displacement of an injector. Just don't add too thick of one or else the oring will leak.
Pizza pig
MD
How exactly is it increasing the displacement without modifiying the plungers?
Go take an injector apart. Then go retake some high school classes, maybe you will see how to principle of volume works?
People make this out to be rocket science. Dont go by what a "diagram says" buy a friggen "core" injector and go to town with a brake caliper measuring tool and a calculator.
Helen Keller sent this?
SSpeeDEMONSS
6mi from the beach, SoCal
Good deal. I have some cores from my stock engine I can pull apart. Looks like this may be the route I want to go.
Garrett
probably getting paid at work to post this from my bionic
Stroker04
Gettysburg PA
Since when have you become an expert? I guess it only takes 1.5 years to become one. Since you couldn't even do an egr delete and oil cooler by yourself...asking over on PSN if someone could help you. If your such an expert why didn't you pull the heads off your truck rather than studding it one by one? I don't understand why you have such an attitude your always butthurt over something. Your ****ing attitude sucks donkey dick.
Pizza pig
MD
Lol!
I do things to test them, push them to their limits. Still holding strong... Cry me a river. Another know it all about me, you must be friends with Rozzay Heiden, captain fearless. Lol
Stroker04
Gettysburg PA
Lol!
Right...I'll send VaJJ over to do your egr delete and oil cooler for you. I'm not captain fearless but there are many people here who have so much more experience than you, but yet you think you know everything in less than 2 years. Think again captain douchebag.
Pizza pig
MD
Lol ive pulled more of these trucks in a year than you have changed your oil. Try again zippy
