Elites tow power atmospheric only?
fluid
Texas
Has anyone installed an Elite tow power atmospheric turbo only?
Elite says by itself should net 50whp with no waste gate needed, for the price it seems like a reasonable mod. Any thoughts?
White_monster
The great white north
Glad to see you here Anthony.
Ya for $1300 you can't get much better option. Pick up a few ponies, drop intake temps which will also drop egts, still looks stock so it keeps ppl wondering and you can install this cab on. Oh, and you don't need head studs or a wastegate to run it, it would be recommended to do the head studs thou.
INFAMOUS
Denver Colorado
Thank you Shane!
I believe I have one in stock and ready to ship. There is a $1000 Core charge. I would also recommend the studs.
fluid
Texas
Sold! sounds like a good stepping stone for me, thanks for the input.
Does anyone know how easy it is to separate the turbos? they look pressed together.
Dzchey21
wyoming
You have to take them out as an assembly and then separate them.
Sent from my DROIDX
fluid
Texas
Has anyone port matched the exhaust inlet of their turbos? i bought a bunch of components off of a wrecked 08 (trans,transfer case, converter, turbo, heads) and noticed there is a lip from gasket diameter to inlet diameter, about an 1/8". would it be worth it to gasket match and polish inlet?
