Cajunhunter67
Hmmmm? Liking the results from the 71mm turbo install! Might be in the works next overtime check! would like to see my EGT's drop! Xrace can be mean on the EGT's.
Other question....should I get studs if I do this? I am still stock head bolts right now.
Has anyone done this setup yet.
BOOM
Apparently some trucks are slightly different then others. I have almost every tool you could think of needing. There is no way I was getting my turbos off without the snap on half moon 10mm... I tried every option that was suggested and that I could come up with.
As far as if anyone is running this set up set. Read the post you just commented in...
Let me know man, we are trying to get a group buy going...
JD..Boss just called...headed out the country to work. Will holla when I return.
Want to loan me that wrench ? int:
He used mine!
He used mine!
