Engine 911, driver bank not firing
mandkole
Northwest
I keep saying it, but this is where I just love the scan gauge. You could have had those codes cleared, the buzz done and it provides data all the time. Agree its more complete, but AE is much more clumsy and rarely needed for most troubleshooting needs.
The 1316 is a general code that is often said to be resolved in the wiring. As ty said, at least make sure the wiring harness up to the IDM is not causing issues. Ohm everything out to the injectors and GPs. Swamps can help with testing your IDM.
campbellflage
Hudson, FL
harness I replaced this am, as well as the gasket, it ohms out good, Cps cause a one bank to fire? I replaced it a couple thousand ago with an international one.
PsdPullerJr
Western PA
My thought was it's cheap and easy to fix, and rules out a no start situation. If for sure have 1 side firing then it wouldn't be a cps but something wiring related to the opposite side.
campbellflage
Hudson, FL
It's for sure only 1 bank firing, pass side firing driver bank no bueno. I can swap it out just for s and g but I don't think it's that, thanks for the thought though!
Did you try wiggling the 42 pin while its running and see if it recovers?
Smokin 6.0
Indiana
Installed my new IDM and same thing pulled all 8 Injectors and I can tell by the nozzles that only 5 of the 8 have been firing the short time the truck has ran
Jomax
Arizona
thats not what I wanted to hear... Mine ran great then just died when idling.. I don't know.
My old truck had that issue from the previous owner. Truck was driving and just dies.
Ended up being the orings were so worn out, there was no oil pressure
Arisley
Arlington, Texas
Personally, just a WAG. Theses trucks are getting OLD. Regardless of mileage, if I was replacing o-rings, I would at the very least scrub out the injector cups with with a green scotchbrite pad. I would actually lean towards simply replacing them if I could afford it.
campbellflage
Hudson, FL
I don't think that is my situation, my bank isn't firing at all so I have to figure out that before I start doing orings for no reason
Jomax
Arizona
WAG?
Jomax
Arizona
Have you tried doing a leak down on each oil rail? You can use compressed air to check for leaks.
Arisley
Arlington, Texas
Completely agree, check wiring, especially grounds.
My comment was based on how many of these similar issues have been popping up recently.
WAG?
WAG = Wild Ass Guess
This also, however, if one entire bank went down at on time, I would be looking first for something common to the entire bank.
