Stroken7.3
I thought this might be a good subject to have for the database. What should they run under normal driving, towing and how do you know when it's time for a rebuild of the oil cooler?
My truck on the highway empty in warm weather the oil temp is 10 under coolant temperature.
Coolant at 190-200, EOT is at 200-210... This is pulling HEAVY.
Did you mean 10* OVER coolant temp? That would be typical based on the trucks I've monitored... Not sure how the oil temp could be LOWER than coolant temp under normal operating conditions since the oil is 'cooled' by coolant that is circulating thru the block??? :shrug:
