Vinny07psd
This might be dumb... But maybe cam sensor?
Was the chip taped in to make sure it was tight? or could it have come
loose? That can fry the PCM.
.Got the fuel system mocked up, and by mocked up i'm powering the pump with a battery charger. LOL Haven't checked pressure yet but its got fuel to the engine. Still no fire.
One thing i did notice is that my voltage is around 10 or 10.5 before cranking, with the GP's on. Engine still turns over and shows 200rpm's, but then it starts slowing down and i lose the tach, or the tach starts bouncing. Scangauge isn't staying on either while cranking. Tried jumping it with our other truck but didn't seem to help much, gonna throw the charger on it and see what that does.
Bingo. There is your problem, First thing first, charge your batteries.
Try Just a SHOT of ether, I know its never a GOOD thing BUT see if it'll even cough off of it. Its worth a Shot...
you are not putting enough gasoline on it to light it up..............
Find an idm yet? How far away are you from Owensville OH?
Not yet, currently at work trying to locate some metal and haven't looked for one. Our drive-thru was broken into around 1 this morning, so i was given the task of working on some security stuff. :cursing:
But i'm probably an hour from Owensville.
