getstuk
When the hubs are in auto, 4x4 does not engage. I thought it would be a vacuum problem after research on this forum but my defroster does NOT kick on when I put it into 4x4 high (just went out and tested multiple times). I'm thinking about going to Autozone and getting a vacuum pump tool to apply vacuum manually, but I feel like I might be wasting my time if the problem does not appear to be a vacuum leak. Edit: Just read about a $40 kit to redo your hubs, if it's not a vacuum problem...
It sounds like it may be the solenoid or the vacuum pump itself...now that I think of it, that tool will help as it will show the pulse on the PSI gauge if it's giving me a pulse or not.
Any recommendations? Going to call around to see if I can rent this tool somewhere...
"Before giving up on the hubs, buy the $40 kit from Ford and take the hubs off and clean them up. Some fresh lube and new O rings and you should be fine for a while, unless you have actual vacuum line problems. Nice to keep the ESOF if you can. My hubs were almost impossible to turn until I cleaned them up, now they are fine (for another winter)."
