Cutting-Edge Diesel
I have a customers truck here that has left me scratching my head. Here is the back story.
We did new heads and studs as well as installing KC stage 2 charger and 190/30s. Truck was low on power and lots of smoke and found it wasnt maintaing at WOT. Customer wanted to install RCD thumper 2 HPOP. Now it maintains perfectly. We had some problems with the injectors going out and ended up changing to new 190/75s.
Now to the problem. It will just haze black smoke out the exhaust at 65+ MPH at sustained speeds. Egts also are on the high side at 1000-1100. With the old injectors I was contributing this to the problems we were having with the injectors. I install the new reman 190s and we have the same problem. So now im trying to figure this out.
Started with tuning. Changed every tune I had and it still does it. Even on a low power tow tune. So not convinced its tuning.
Truck is also on 37s with stock gears. So thinking maybe its the tires causing it with extra load and stock gears I install stock tires and wheels. No change,
Next I changed the turbo with a stock one. It lowered the egts but it still smokes. So not convinced it was the charger.
Also changed the FICM, air filter, boost leak test, exhaust leak test etc.
Data logging shows my boost and injector PW at cruising are higher than Charley normally sees. Boost is 6-7 range and PW is at 1.2 at 65mph. his truck with a stage 2 is at 3-5psi and .9-1.0 PW and 800egt
Unfortunately this customer lives about 7 hours away from our shop and ive already had to go pick it up once because of the injector issues so I dont want to have to go back!
Anyone have experience with this combo or this issue?
