BWCbuilt
How are the outer hubs set up on these? I would like to make one an 8 lug and SRW width to slide under my project truck. How difficult would that be?
same concept, the actual "beam" part of the axle sits a good 4-6" lower than the spindlesWhat about building a custom front axle like what you would find under a low pro international 4600? With a drop built into the axle?
I don't think the I beam solid axles have enough drop to clear the engine
Sent from my T-Mobile G2 using Xparent Green Tapatalk 2
