F-superduty 2wd front axle questions
rat49f6
Vernon,NJ
Check town and country auto in amanda ohio?
Sent from my T-Mobile G2 using Xparent Green Tapatalk 2
BWCbuilt
central US
nothing there last I checked, after doing a little more thinking, I might just make my own tubular a-arm suspension for the front, It would probably wind up being cheaper, and less of a hassle.
rat49f6
Vernon,NJ
basic mustang 2 set up with chevy spindles
I'm trying to remember y I used 01 -07 set up ... Can't remember y it was better than earlier
rat49f6
Vernon,NJ
reason they wont work as is is because of limit in range of motion
i can only get 8" of flex out of the top arm before it bottoms out the ball joint... and i need atleast 10
the F-Superduty wasnt in the yard when i got back ill try again tomorrow
BWCbuilt
central US
So rather than buy a clip I should probably just buy spindles and make my own A-arms? sucks to have to do, but if its the only way......
rat49f6
Vernon,NJ
Plenty of companies make arms
Check out michigan metal works
Thats who I will be using
Without factory mounting points on the frame it makes it difficult to keep the wheels true thru the entire cycle of a bag...just something to think about
BWCbuilt
central US
I have more time than money, and I also have a full machine shop at my disposal..... I would rather build than buy. I don't see what would be so difficult about fabbing up mounting points?
rat49f6
Vernon,NJ
The problem is at certian points of the rotation the wheel will actually toe in/out ... 2000ish rangers are famous for this
BWCbuilt
central US
I guess I am not seeing the logic in what you are saying, can you provide a link to some relevant information? I dont see how a correctly engineered custom A-arm suspension would be any less effective than a factory one
BWCbuilt
central US
any info rat? pretty sure I have my rear suspension drawn out (cantilever four link) still trying to decide the best way to do the front
rat49f6
Vernon,NJ
Can't find any write ups on what I'm talking about
Ill keeping looking
Are you doing the rear with a triangulated 4 link or paralell?
rat49f6
Vernon,NJ
Seems like it is totally possible to lay frame on beams
Google... Bagged 96 f150
Djm dream beams seam to work best and I loved mine
BWCbuilt
central US
Triangulated.
I have seen them slammed with beams, but I dont like how bad they camber in when slammed, you also have to notch the frame to account for the tie rods, and it puts them in a hell of a bind from what I can tell.... but I am no expert either....
rat49f6
Vernon,NJ
take notice which brand each truck has ... some brand beams camber less than others
I did paralell with cantilever and im very happy with how it worked out
rat49f6
Vernon,NJ
Sd don't lay on beams
I would have done a chevy clip but felt better about making arms work because I'll be running a 500 hp engine ...hence why I asked what you are rubbing engine wise
