Factory Limited Slip - Synthetic AND Friction Modifier?
PsRumors
Cartersville, GA
Changing the gear oil in the rear axle which has a factory limited slip unit. I am using Valvoline synthetic 75w-140 ( http://www.autozone.com/autozone/ac...hetic-gear-oil/_/N-255s?itemIdentifier=977483) which states "Limited Slip" on the bottle.
So is a friction modifier also needed?
My limited slip still works after 16 years and 130k miles. I want it to continue to work after the fluid change. Just don't have the money for a Tru Trac at this time.
Redpower
Central Iowa
I think that is correct. I had to add the friction modifier to the rear end on my F-350 and is not a limited slip rear end. It's not a big deal to do- the stuff is in a tube and you just put it in the fill hole.
mudslinger02
MN
I used the Valvoline 75w-140 in my F-150 just over a year ago, didn't add friction modifier and I've had no problems. And yes it does have limited slip
backwoodsboy
Merica
Don't add it to start. Typically a fluid designed for LS won't need the additive.
Once you have changed the fluid, find a paved parking lot and do figure-8's at moderate speed (~10mph). If you notice chatter then add the friction modifier until the chatter goes away.
