Factory tie rod end taper?
97strokerHD
Can anyone tell me what the factory tie rod end taper is for a 92-97 ball joint dana 60? Looking at buying tapered inserts and not sure which ones to get.
Lt.Dan
Visalia, CA
Could drill it out to a straight hole if you are running a heim (or equivalent). Nothing wrong with that. And keeps you from spending more money.
ncollins64
winchester springs, tn
I bought some steel inserts from ruffstuff ^ specifically for these trucks and had my tie rod hole drilled out to accept a gm 1 ton tie rod. Works perfect.
m_j
the taper is usually 1.5" per foot same as chevys, the depth/size is different
97strokerHD
Probably going to end up getting the ruff stuff tie rod kit but with an untapped drag link hole so I can ream that ro factory size and still run a factory drag link.
